JGS turbo kit
1995s-14
I want to turbo my KA24de block and have been shopping turbo kits. im trying to be cheap like everyone else. i heard the JGS kit is good and am wondring what the difference between .48 A/R and .63 A/R is going to make. can anyone explain? what else will i need to complete my kit for 250-300hp? heres a link http://www.jgstools.com/turbo/index2.html
1995s-14
are there any fuel system kits out there for a good deal?(injecters, pump, rail, fuel management? and what a good piggy back ecu route?
coolbone28
What is your budget?
1995s-14
i want to have a full kit for somewhere around 2500 or 3000. JGS kit was 1700. then i need ecu, rails, injecters,pump how much more will that be(recomendations?) and what else do i need
480sx
Car: 1996 Pearl White 240sx
Between 250-300 hp .43 ar will be fine. It will have a faster spool time than a .63 ar.
JGS kit is a great kit, cast manifold and all. Perfect for your goals.
Also check out http://www.treadstoneperformance.com/ . They have good prices as well, not as well known as JGS however.
You will need a fuel system upgrade and control unit.
Check the sticked posts at the top of the page, you should read all in this link,zerothread/226410and this link ---->zerothread/99647
coolbone28
Well you are also gonna need an intercooler and stuff for that. Figure you can get some deatschwerks inj, find a good deal on an N62 mafs and some form of tuning. Enthalpy is an easy and great way to go about it. thats 500 bucks though. Then you will need miscellaneous stuff like gauges, and a clutch to hold that power. I honestly dont see you getting out of this with less than 3k...on the generous side. BUT it will be a pretty solid and reliable setup/.
tjmhillz
Car: 2001 Lexus IS300 Turbo
i heard alot of good things about jgs. i hate to tell u but there is no such thing as a budget when ur boostin your car.. you will end up going way over your budget in no time... its the little things that will add up too.. good luck though
j-z
Car: 95 240sx
if you want more horsepower than torque go with the .63 a/r... if you want more low end torque go with the smaller .48 a/r housing. i had a .63 a/r on my built ka-t and i hardly ever saw lag and thats with stock bore, granted it was a stage 1 exhaust wheel... from experiences with my civic i had a 63. a/r on there with stage 3 wheel and went to a .48 a/r with stage one wheel that was clipped, and all the power just went away. i lost 50 whp after i dynoed it, but i also added on a different exhaust and intake manifold, and put a full 3'' exhaust as opposed to having just open downpipe with the .63 setup. lets just say this, id rather have the lag and more power that the .63 a/r provides. exhaust wheels play a big factor too.. it couldve been a number of those things that contributed to me losing power but the biggest factor was the exhaust housing and wheel change. go with the .63 imho.
1995s-14
Logan76
Car: Junk
You dont need a new fuel rail for 300hp, thats incorrect, all you need is a walboro pump, some 650's, and a Z32 maf, then if I were you I would buy Emanage Ultimate for your budget, and a new clutch.
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
Hey Zinda, what's up?How's the booger?
Sorry for the threadjack.
