JGS manifold
Powashiftin
which manifold would you recommend? ... or what manifold are you KA-T guys rocking?
vadem
Car: Drifting like a mofeeger
You can go wrong with jgs. Thats what i got, I'm very happy I got it. I bought the unwelded version. Took me 1h, to weld it and fit. IF you dont have access to one then I suggest to get the welded version, for like 200, mine cost me 145 shipped.
Drift Machine
Car: 1991 KA-T 240sx
I have the JGS manifold on my car and I like it so far. But then again I haven't really had a chance to abuse it......yet....
andrave
Car: 1989 Nissan 240SX Coupe
I'm in the process of building the tubular kit, blah blah...nervous about welding it myself, cause my welds suck so far. But I'm getting better. I might just cut it up and tack it and take it some place.
anyway if I ever get it done I'll post it up on my site, which is in my sig. As of now I'm still waiting to get my turbo extensions so I can design the manifold around them.
DriFt3r
Car: Racing and Drifting
can I use MIG to weld? I have .035 wire with about 125 amps? what do you guys think
DriFt3r
can I use MIG to weld? I have .035 wire with about 125 amps? what do you guys think?
andrave
yes JGS recommends a minimum of 100 amps so 125 would be adequate. If you are good at welding go at it.At the moment all we have is an ARC (stick) welder that is plenty big enough, and an 85 amp wire feed. The smaller wire feed is much easier to use but gives ****ty welds and wouldn't do any good on the thick tubing and flanges. the arc one is a total ***** to get clean welds out of. I just need more practice.
turbotruck
Here's my JGS wouldnt suggest having them weld it up. I found out putting mine together and fitting everything, that there is extensive grinding and porting that needs to be done to make it FLOW.. I spent probably 12 hours fitting and porting, but it is perect now. oh and it consist of 10 pieces welded together
rco8786
i bought the one from jgs that just needed the radius plate/flange welded on. i used a cutting wheel/metal file/and a 150amp wire-feed and was done in about 20-25 minutes.
The only thing i regret is that i ended up having to disconnect the top A/C hose in order to fit everything in there(welded it half an inch too far forward)...im thinking of doing some custom work sometime in the future to get my AC back, but i dont like using it anyway so oh well.
E Dogg
Car: 1997 M3 sedan
1988 TII RX-7 10th AE
1990 Ford Bronco XLT
where can i get a jgs manifold?
Magnum
E Dogg wrote:where can i get a jgs manifold?
http://www.jgstools.com/turbo/index2.html
E Dogg
Car: 1997 M3 sedan
thanks, i may need an odd flange though....
LongIsland240
Car: 92 S13 Hatch
DriFt3r wrote:can I use MIG to weld? I have .035 wire with about 125 amps? what do you guys think?
I hope thats good enough, thats what i used! :) seriously though...that should be fine.
E Dogg
Car: 1997 M3 sedan
does anyone know what flange a s4/s5 rx7 turbo uses?
downhillspecialist
Car: cars
E Dogg wrote:does anyone know what flange a s4/s5 rx7 turbo uses?
t3 i think...
AN89HATCH
Did you guys kit just fit rite togeather? I ordered my jgs log type manifold for my sohc ka, and received it today, but nothing lines up. It needs to not only be welded, but cut in order to make it be alignied. Also there is like a 1 inch gap in the middle of mine that will need to be filled with one of the cut pieces. maby its just the sohc ka manifoldS? I hope the muffler shop dosnt charge to much to do the work :rolleyes
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
If you ordered the ~$150 kit, it's a DIY setup. Just a flange and a bunch of pieces, you cut and wled it together.
They also sell a $250 one that comes welded, but you have to cut the hole for the flange and then weld that on.
You just bought the cheaper kit I'd bet...
- Brian
Tx-Sx-FS
Car: S13 KA-T
i also bought the cheap kit..but all i need now is like the plans or deminsions of someones SOHC that is done (turbo truck) and how much i can expect to pay at a muffler shop to have it done...if anyone is willing to trade me there already constructed one for a non assembled one..then id be willing to do that...i want to get this done asap and pay as little as possible...thanks and hope someone can help me
andrave
I have an 80 amp mig, do you think that would be enough? initially I was thinking no, but I've been welding a lot and I"m pretty sure if I switch it to high I should be getting penetration...
WDRacing
Get a piece of 1/4 scrap and have a go at it. Thats really the best way to check for the proper weld. If your unsure you can usually take it to the local welding supply shop and have them take a look. Thats what I did on my first few welds.
I jacked up my first JGS and had to grind all the welds down and run new beads. The first ones were effective, but ugly.
If you weld on both sides of the flange and radius plate you should have plenty of penetration.
Tx-Sx-FS
Car: S13 KA-T
can someone please send me pics of different angles of their ka24e sohc turbo manifold? if so send to [email protected] and thanks
MarkEmark
Car: fully-built '95 240sx KA-T
I've been running my JGS manifold for over a year now at 9 psi and haven't had a problem yet.
KNOCK ON WOOD
