jesus some plz help no fuel for sr redtop swap
l314ckhe4rt
Car: 240sx
okay i took this setup off of a buddy's car put it in mine but it doesn't start. i have found out that theres no fuel going through the lines. the fuel pump doesn't make any sound so i belive its dead or i have read that it might have something to do with the ecu. i need help plz i am going nuts
Justin35ll
Car: s13 coupe sr20det
See if you're getting power to the pump, check fuses, relays, wiring, etc
s13_chris
Car: 90 240sx Hatch
the EXACT same thing is happening to me. Hope its not as bad as mine. I need to get a new ECU! Something you can do it put a hotwire to the fuel pump and see if it turns on. For example bring a battery with a charge, get some wire and touch one end to the + terminal and the other to the power wire on the fuel pump, if it starts running then your fuel pump is fine. If not, new fuel pump time.
Check fuel pump fuse in the engine bay, switch the EGI and EGI PUMP relays, and if all that fails, take a test light or volt meter to your Fuel Pump Relay wire coming out of the ECU. Search for a ECU pinout for the year of your car (regardless ka/sr) because no matter what motor/ecu you put in, it still will use the same wiring going to all the components in the car.
If you understood that plug the test light into the fuel pump relay hole, with the key off, and once its in there securely with a good ground, turn the key to the on position and see if it lights up. It should only light up for 5 seconds.
l314ckhe4rt
Car: 240sx
hey thanks for the info i found out that theres no power in the some of the fuse area. happens to be the one to the fuel pump. so i need to see if i can get power in there somehow. hope it doesnt have to do with the ecu
slidestyle69
Car: 92 s13
Double check ur wiring..if its done in butt connectors double check that sh** real close with a diagram for the wiring.....if thats all correct...pull the cover to the ecu and make sure along the swap a wire hasnt been damaged and crossed another wire..this would led to burning a circuit in the ecu...i know this cause it happened to me and jus so happened the circuit which was burnt was connected somewhere with the fuel pump..soldered a new circuit and fixed the crossing wires and BAM..fixed but the the relay could also be a problem too
l314ckhe4rt
Car: 240sx
relay? where can i find the relay?
l314ckhe4rt
Car: 240sx
okay now i know for sure my problem with the fuel pump has to do with electrical stuff. the pump i just bought is new but still doesn't prime. i checked the fuse box and out of the 3 10A fuse only one has power and the other two doesn't am i missing something that suppose to connect somewhere? can some one show me a wiring diagram to the fuse box i seem to not be able to find it
