willmoodom »
https://forums.nicoclub.com/willmoodom-u155679.html
Sat Jul 16, 2011 6:44 pm
Man! every time i think this car is awesome, a part needs replacing and my enthusiasm turns to dread. not because it needs replacing, but because its a b**** to replace! lately Ive been tracking down a faulty shift pattern with the transmission. the shifts in "D" mode were due mostly to tps which Ive corrected. half throttle shifts are on point. Now WOT shifts were a bit wild and scary. Scary in the sense that i might blow my engine. installing the nico ecu along with the already installed 94 tcu -as advised by big Wes, cleared alot up and brought the redline down to earth. however, she still hangs a bit like she waiting for me to shift or let off the gas. i di the transmission diag. and got the "A/T CHECK" code which consists of inhibitor,1 position switch, kick down, closed throttle, and display. the last 3 have been eliminated and proven to work. As for the inhibitor and 1 position, add on the fact i found out from an earlier post these 2 switches are connected to the same fuse. i did a volt check according to the man. and could no get any numbers. theses 2 switches affect the transmission by not allowing manual shifting of the unit. a little while ago i got under the car to take a look and damn! almost required to remove the transmission to replace the inhibitor. Especially if there's any rust build up, like on my car. it almost appears that though the inhib. switch is outside the transmission, it may be connected to something inside the transmission. Can anyone confirm that? i say this because in the man it shows a oil seal on the nut you have to take off. and mine is rusted to the point that if attempted, 98% chance it wont be reusable. i haven't confirmed where the 1 position switch is located. talk about neglect. people just drove through salt and thought nothing of a good undercarriage bath. what i need is this:
is the inhibitor connected to anything inside the transmission? 1 position switch?
does anyone have a used one?
quicker way to replace?
if not connected to anything in the transmission, what signal is being sent to the tcu for gear selection?
