2011 Juke SL 1.6 Turbo
-I have scoured the internet. I am spitting a 301 code (cP0301 - Cylinder 1 Misfire Detected)
-it also flashes at me when this event happens then goes away when I take my foot out of it
-150000 miles
-Original plugs (LOL I know start there)(will do this weekend)
-Oil leak by the coil pack from the timing chain recall....will try and seal that up may be shorting out the coil pack
-Will swap #1 and #4 coil pack when I do plugs
MAF and O2 replaced
********Car accelerates fine under normal driving habits, and will go fast from a light or initial acceleration down to the floor until it hits the higher RPM when I have my foot in it.
*************Turbo, appears to be functioning correctly on my little readout
I did see something about an intake leak or leak to the turbo hoses clamps ????? Pictures of this would be helpful if someone has done this
Crank Sensor and cam sensor next on suspect list?????????
Thanks All!!!!!!!!!
