jecs ecu???
josephg15
Car: 1992 240sx
i got a jdm ecu with my sr20det swap and the ecu had a toggle switch...i opened it up and there was jecs chips in side...has anyone heard of jecs? and the toggle switch can be switched to N or T (N-T) there is also a dial that you have to use a tiny screw driver to turn left or right...maybe to turn something up or down...not too sure i am not able to post pics on the website...but i can send you a pic if you have any idea what this is about...thanks
SpeedRacer1
Car: 1990 240SX, G35
JECS is the stock chip manufacturer, all Nissan ECU's probably have JECS microprocessors.
wildacexxx
Car: 2002 Q45 nav sport
the toggle switch is probably to run to different maps for different boost settings. good luck trying to figure that out though
