after the coilovers i picked up some kouki tails. (i want to keep a semi good balance of a good looking clean car/ one that i can get on and race someone/drift a little bit..so thats how im going about buying parts)
then came the decision of what i was going to do about a motor. i had the thought of and rb25 or rb20 and then a little change to an sr20 but in the end it came down to taking the ka-t challenge. so one late friday night i took the 2 hour trip up to nh to pick up a (begginers turbo kit) kit included sr t25, megan bottom mount manifold in good condition, jgs oil kit, sr 370cc injectors, z32 MAF, romtuned ecu for 7psi (s13) and an s13 semi cut harness. not going to use the harness or the ecu bc of the fact it being s13. i was thinking about buying just the kit but then the kid said he barely had time to pull the motor and everything was still on it. so i said ah wth and bought the motor with it. (blown) not sure what went wrong lost compression unknown miles. also got another t25 since the one on the motor blew smoke so he threw in a good one. (dont trust either of them since theres more shaft play in the supposedly good turbo) going to end up either rebuilding the bad one or getting rid of both and buying another t25 or t28. so hears some pics of the motor and turbo kit after i dissambled.
beat up s13 harness
370cc injectors (will be flow tested)
heres the manifold, both turbos, z32 MAF, stock MAF, dump pipe and ka starter
another pic of motor (going to weld another bung onto my other oil pan, since it being so low isnt good...suggestions??)
