92vert240 wrote:Well i checked all the fuses everythying looks good. Checked for power on the ECU and i only have power at pin 109 red wire. Not anything on pin 49 or 59 that say ECU POWER in your pinout.
As for tha ground, i dont even have that eylet on the harness. I used the KA harness and checked with my other KA which also doesnt have that ground wire. The s14 lower harness does have it but it runs directly to the starter i believe or alt. Either way like you said this should be the problem.
I cant think of anything else it coul be. I followed your instructions to the T. Everything was soldered with flux, shrink wraped, taped, and loomed.
My friend thinks its a bad ECU but i doubt it. Where can i start testing stuff with the volt meter to trace the problem? Thanks. Should i just e-mail you insted rather than clog up this thread? Would that be easier?
the ground shown in the pictures above is an extra ground for the ALT. it helps to suppress radio noise.
Check to see if you are getting power at the BLK/RED wire at the big grey plug by the battery
Check to see if you are getting power at the BLK/WHT wire at the big grey plug by the battery
test these with the key in the ON position
if not, turn the key to ON and ground out the RED/BLK wire on the brown plug by the battery
the RED/BLK wire is the wire that comes from the ECU to trigger on the ECCS relay that powers up the engine harness. it does this when it the ECU sees voltage from the BLK/RED. this will be a good frist step.
also check for power (key ON) at the large BLU/RED wire at the coil pack harness.
