JDM Yellow foglight capsule retrofit
Archangel1183
I did a retrofit for a guy on another forum. This isn't a Nissan but its usually the same for most fog lights. I took a few pics of the steps. These are the same capsules that I had for sale here.
Tools used: Screwdriver and Dremel with 2 types of cutting bits.You can find them at Home Depot.
Started by cutting out the stock bulb holder with the circular cutting bit.
After cutting it off, I made the hole bigger with the smaller metal cutter.
I kept checking to see if it fits so I wouln't make the hole too big. I wanted to get a snug fit.
Test Fitment and it fit fine. It touches the inside cutoff shield a bit but it doesn't get in the way.
Finally I used silicone around the inner edges to keep it in place. He's gonna let it dry for 24 hours before installing them on his car. I'll post some night time pics when all done.
Daytime shots
Night time shots
They look a lot brighter in person. The camera and angles suck. :/
Modified by Archangel1183 at 9:42 PM 1/24/2008
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
pretty sweet, looks almost identical to mine.
Archangel1183
srpowered240sx wrote:pretty sweet, looks almost identical to mine.
Silvia front end?
keith0486
not at all i like them.
srpowered240sx
Archangel1183 wrote:
Silvia front end?
nope.
Archangel1183
nope.
Nice.
Archangel1183
Here's a few of my CRX and Supra with the same capsules.
Supra
CRX
keith0486
wow those are bright.
Archangel1183
Updated the first post with Night time pictures.
RazoE
Car: 1989 Toyota Supra
Hey Ish, you can also use USDM Acura Legend capsules, but in order to remove those from their housings, you need to break the plastic on the outside, junk yards are usually littered with Legends..
ag240
Car: 1993 Hatch, 1989 Hatch SE, 2010 Fronty SE
Hey do you have any more pics of that crx? my friend has the exact same colored crx. He'd like to see what his car can look like with a little work.
1990300zxNA
Car: NISSAN 300ZX
not a big fan of yellow but on that celica they look realy good
cornuts
Car: 91 nissan 240sx
as for these jdm yellow lights, were did u get them?
