I would love to agree with you on the motor vs. engine discussion... But unfortunately I cant... According to the proper definition of a motor it can be powered by fuel, gas, air, electricity, or any other form of power. An engine, however, must be an internal combustion device. Therefore, an Engine is a type of motor, but not all motors are engines. I had argued for years with people over the motor vs engine discussion and finally looked up an article and was proven wrong... It broke my heart. Threw my whole concept of reality into question lol.NolimitZ32 wrote:Physically the only difference between the two is the position of the oil filter tree and a couple other insignificant things AFAIR. Now as for buying a JDM engine (its an engine, a motor is driven by electricity), I recommend that you read through he JDM Engine Experiences thread before making your decision.
jdm-engine-experiences-noobs-read-t530009.html
http://www.engineering-dictionary.org/motorMrFeesLaw wrote:I would love to agree with you on the motor vs. engine discussion... But unfortunately I cant... According to the proper definition of a motor it can be powered by fuel, gas, air, electricity, or any other form of power. An engine, however, must be an internal combustion device. Therefore, an Engine is a type of motor, but not all motors are engines. I had argued for years with people over the motor vs engine discussion and finally looked up an article and was proven wrong... It broke my heart. Threw my whole concept of reality into question lol.NolimitZ32 wrote:Physically the only difference between the two is the position of the oil filter tree and a couple other insignificant things AFAIR. Now as for buying a JDM engine (its an engine, a motor is driven by electricity), I recommend that you read through he JDM Engine Experiences thread before making your decision.
Oil pressure sensor attaches to the oil filter tree. EDIT: ON USDM MODELS ONLYitsa300zx wrote:Only the oil pressure sending unit needs to be moved to the other side. All else is the same
Oil pressure sensor attaches to the oil filter tree.[/quote]itsa300zx wrote:Only the oil pressure sending unit needs to be moved to the other side. All else is the same
So here's the problem...the car is violently shaking and turbos aren't working. Guy I took it to said there was a leak and he changed the coil boots and that didn't solve the problem. He said I have 2 completely dead cylinders and that I need to take it to someone who does rebuilds.NolimitZ32 wrote:Go rent a compression tester from autozone and run a compression test on all the cylinders, also if you know anyone with the tools and know-how get a leakdown test done before you go throwing money at the problem. If the issue is electrical you will be mighty pissed having spent all the time and money on a rebuilt engine only to have the problem resurface.
gja06 wrote:So here's the problem...the car is violently shaking and turbos aren't working. Guy I took it to said there was a leak and he changed the coil boots and that didn't solve the problem. He said I have 2 completely dead cylinders and that I need to take it to someone who does rebuilds.NolimitZ32 wrote:Go rent a compression tester from autozone and run a compression test on all the cylinders, also if you know anyone with the tools and know-how get a leakdown test done before you go throwing money at the problem. If the issue is electrical you will be mighty pissed having spent all the time and money on a rebuilt engine only to have the problem resurface.
itsa300zx wrote:^^^ This guy does not seem to know his way around the Z32. Have you checked the injector/connectors yet?
There is no mention of that anywhere in this thread. Two dead cylinders could easily be injectors or PTU or just a bad connector. Do you know which two cylinders?
Agreed with NolimitZ32, also get someone in your area that knows these engines to look at it before dumping too much cash into a rebuild.
