exacyzm »
https://forums.nicoclub.com/exacyzm-u99923.html
Fri May 22, 2009 6:10 pm
I have read that the JDM CA18DE has a compression ratio of 9.5:1, and on the AUS spec (and some other) CA18DE it's 10:1.
Is this correct? I have never seen a JDM engine have lower compression than it's counterparts.
All the stock power figures I have seen are exactly the same for the different versions but I would have thought if the JDM version was 9.5:1 it would have to make less power than the 10:1 versions. It doesn't seem to make sense.
If this is in fact true, what is responsible for the 0.5 less in the JDM version, different pistons, thicker headgasket, a combination or something else?
