_XLR8_ »
https://forums.nicoclub.com/xlr8-u131430.html
Mon Jun 22, 2009 5:28 pm
Bit of an update. Basically followed the diagnostic steps 1 by 1 in the FSM eliminating problems as I went. ECU is now showing Code 55 No Malfunction but still won't start. Power to the coils is good and continuity to the transistors is fine so looks like I'm almost there. I bought an Injector NOID light and found the injectors aren't pulsing. Checked continuity between ECU and each injector and that is good so it's got to be a power supply issue although I cant find the 4 pin engine harness sub-connector that is supposed to be next to the 8 pin injector harness connector . A shove in the right direction would be appreciated
Another thing I should mention is ECU Talk is telling me the timing is 46* BTDC, but I'm not sure if that is accurate or not.
On another note, the TCM is still flashing a few codes (12, 13 & 24) but none of them seem to be messing with the ECU function anymore and are only related to the TCS/ABS input/output signals
Modified by _XLR8_ at 8:38 PM 6/22/2009
