S13 Charlie »
https://forums.nicoclub.com/s13-charlie-u18503.html
Thu Dec 23, 2004 8:23 am
Well, for JDM turn signals, I assume you are referring to the half-amber, half-clear lights, right?
If so, I actually just bought a set from ebay without realizing that they contained no bulbs, or wiring of any kind. So, I did what any self-respecting engineer would do and figured out how to wire them in. Mind you, wiring is not my favorite passtime. Anyway, since our turn signals only have one bulb that acts as both a parking light and a turn signal and the JDM lights are setup for two bulbs, there are some components you need to buy. I went to the local Kragen and picked up two small sockets that fit the lights and then the two bulbs (194's) that fit the new sockets. I'm not sure what the part number is on the sockets, but if you had the JDM turn signal housing, it's pretty obvious which one would work. As for the wiring, I busted out my trusty FSM and located the wires to splice for proper operation. I used quick-splices and spliced the ground from the new socket to ground in the harness (black) and for power, I spliced into the wires that provide parking light function not turn signal function (red/green and red/blue) on each side. Then I popped the bulbs into the new light housing and voila, both lights light up, but only the amber bulb blinks.
Man, that seems long-winded, but it's kinda hard to put in words. Can't help you with the ebay intakes, I have an AEM and I like it.
Hope that helps.
C
