JDM TT Engine, Been sitting four years
Stryker14
Car: 1993 300zx Convertible
1964 Renault Caravelle Convertible
2002 BMW 530i
Yes I bought this JDM TT Engine, it has been in a storage unit for four years.
What to do with it before putting it into my Convertible?
Just a timing belt change, cam seals and the usual deletes? Of should I get a seal and gasket kit and take it back to the block?
Opinions appreciated!
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
I'd do a full seal kit. Maybe not all the way to the block, as HG's don't have a tendency to break down, but if you have the means and the engine is already out of the car....
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
^^^ agreed 100%, sooooo easy with the engine already out. The best couple hundred dollars you'll ever spend on a Z32.
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
Also, pour about a table spoon of ATF into each cylinder and crank the engine a few times by hand. This will help clean and loosen up any crud that been sitting in there.
