jdm swap
1995Q45havoc
Car: 95 Q45
i have 95 Q i wantted to do a jdm swap to it ..but will everything bolt up with the same year motor if its jdm.... please imput is well appreciated
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Should bolt right up, except the year changes to the Nissan president were far different from the Infiniti Q45.
1995Q45havoc
Car: 95 Q45
Paul wall what do you mean when you say{except the year changes to the nissan president were far diffrent for the Q} can you ellaborate more on that please
Infinitiguy19
In Japan there is no 1990-1993 and 1994-1996 Nissan President. They changed a little differently from what I have read. I am not sure what year the Nissan President VH45DE will match your car.
Check the Crank Angle Sensor, Injectors and Power Transistor for starters because those changed from 1990-1993 and 1994-1996.
1995Q45havoc
Car: 95 Q45
Paul Wall wrote:In Japan there is no 1990-1993 and 1994-1996 Nissan President. They changed a little differently from what I have read. I am not sure what year the Nissan President VH45DE will match your car.
can you ellaborate more on this please im not understanding this......thakyou
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
basically the 90-93 and 94-96 engines are a little different... The ECUs and everything work together, however you must splice together the CAS harness if your putting an older model engine into your 95...
also, on really late 95s they went to many of the OBDII style connectors on stuff.... why are you looking at doing the swap?
1995Q45havoc
Car: 95 Q45
elwesso wrote:basically the 90-93 and 94-96 engines are a little different... The ECUs and everything work together, however you must splice together the CAS harness if your putting an older model engine into your 95...
Well i got a shell of a Q that has no motor or transmission...but i also have my baby which is my daily driver so i wantted to put a jdm swap in my daily driver take that motor an put it in the shell to sell that car an reimburst my pocket for the swap..Im always trying to make the Q be a better beast then what she is....So when i call for the swap ima ask the guy to try to get me a motor that was made in early 1995 being that my car was a january 1995 production so im not all the way OBD2 yet....i appreciate your advice...i just like to double check on things before i go and hang myself..
elwesso
2007 BMW M Coupe
94 and early 95 were the same, its the really late 95 or 96 you cant use...
BTW be sure you either have them take a picture of the valve cover off or go and inspect it yourself. just because they advertise 60k miles, does not mean its got 60k miles worth of wear. my point is that 60k of stop and go japan driving is probably about the same as 150k of mixed US driving.
Q45tech
Except while under the 60k warranty the Japanese change their oil at dealers every 90 days!
