^^^ True, but I believe you need to swap the oil fiter tree over to the other side, before dropping the motor in.t.mcginley.jr wrote:If the oil filter is on the passenger side of the engine, its a USDM. If it's on the driver's side, it's a JDM. Because the steering is on the other side in Japan (RHD), they moved the oil filter tree to the other side.
ahhh that's what I meant to say. I wrote that when I was way too tired lol there wouldn't be any place to put the oil filter tree unless the blocks were different. Can you see the JDM oil sender unit easily from the side its on? Or is it buried in thereEdit: just looked at my jdm motor, and the oil filter is on the same side as my usdm motor. The difference is only the oil pressure sender location.
How much is he selling it for? Any reason you want this one in particular? JDM engines are known to be headaches, if he has it high priced, my be worth to look for an actual 300zxTT, not swapped from an NA. Not trying to deter you, just curious.C4ORCE wrote:hey guys im new to the forum and im considering buying a z32 and i have a few questions. a few years ago i had a z31 NA with a turbo swap running around 15psi.it was rediculously built but i had to sell. now im looking at a z32 NA with a tt swap. the guys says its a JDM motor but how can i be sure is their a way to tell a JDM from a USDM?any help would be greatly appreciated.
If your gonna replace it, now would be the best time to just get a JDM bumper. They are about the same price, sometimes you can get it cheaper. Always a clean look.C4ORCE wrote:all it needs is a front bumper which the one on it isnt bad but slightly damaged i was gonna replace with a tt bumper anyway so no big deal and the driver seat is a little tore up on the side
