JDM SR20DE, In the middle of swap and problems!!!!
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
OmegaX1
Car: 1991 Sentra SE-R with a JDM SR20 Swap
So im in da middle of the swap and i jus noticed.....a lot of my plugs are different, the ECU plug is the same but all the other plugs that run with the ecu are way different....PLZ HELP!!!
My swap is a 1991 SE-R sentra, witha messed up SR20de, so i was gonna drop a JDm sr20 i accuired into it, i was told it would be a straight bolt on
THE JDM SR20DE was originally bolted on with an auto transmission but i changed over the original transmission and flywheel 2 the JDM motor
nametakennow
Car: '06 MINI Cooper S
You need to use all US electronic parts.
OmegaX1
so im gonna have 2 start splicin wires???
nametakennow
Not if you use US sensors. The only different ones should be O2 and maybe the MAF. I suppose I should first have asked if you're using a similar-year JDM engine to your 91.
OmegaX1
Ok so its all in everything seems right..but... there no fire out of the coil, ive tried 2 coils on it so i know the coils not bad, I know somewhere i messed up on the wiring, does anybody know what the color of the wires that plug into the coil are? Also where is the ignitor chip? or does it have 1?
JustinVero
Car: 2 1996 Nissan 200sx SE-R's
Make sure that you have swapped all of the USDM sensors over to your JDM motor, especially the 2 water sensors, those are a pain to change with the motor in the car.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
