JDM SR20 Vs. USDM SR
S13 Power
Got a question for all of you..
Whats the diffrence bewteen a US SR20 and a JDM SR. Are all SR's japan built of are some built here in the states?
I know the JDM SR doesnt have all the emision crap. what about HP rating and such.:confused:
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
the us only has 1 version of the SR20, japan has 15+ versions of the SR20
US:-FWD SR20DE ~140hp
Japan:-FWD SR20DE ~140hp-FWD SR20DET ~210hp-FWD SR20VE ~190hp-RWD SR20DE ~140hp-RWD SR20DET ~205hp-RWD SR20DET w/ VVT ~210-250hp-AWD SR20DET ~210hp-AWD SR20VET ~280hp-SR16VE ~?hp-SR18DE ~?hp
S13 Power
Thats a lot of engines. Was the SR20VET produced by nissan? or is it just a SR20VE+T? What car came equiped with that machine?
Anyone which SR20DE had the 10.1 compression or something like that? I know the US SE-R's had the 9.5:1.
I just purchased my engine from soko. Theyre sending an JDM SR low port but i forgot whats the compression ratio on it. I asked him about the compression test and he said their 128 or better??? I thought SR20's were rated at 178 or higher? he said it would go up a little higher when everything like the electricals and such were all hooked up.
DJ_SpaRky
SR20VET was produced by Nissan in 2000+ X Trails
Some Links:
http://nissaninfiniticlub.net/...26840
http://nissaninfiniticlub.net/...=9512
undertaker
Car: C33
-SR18DE~140hp-SR16VE~175hp-SR16VE N1~200hp.
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
U.S. actually had two SR's.
The 91-99 SR20DE was ~140 HPThe 00-02 SR20DE was ~145 HP
The 00-02 used roller rockers with reduced frictional loss to give it the extra 5 HP.
irax
Car: VQ35DER Powered S14.3
whats the difference between the usdm sr20det (found in g20t) and the jdm sr20det.. like is the ecu progaming different ? are the cams different ? is the block different ? just wondering..
and j-spec.. did you froget about the 270sx, special edition of the s14 zenki that had 270hp ?
Onizuka
The G20t does not have a SR20DET, its just a trim level, still has the SR20DE.
no such thing as a 270sx, unless your talking about the japan-only 270R by nismo. Special editions dont count because there is no way in hell you will ever get one.
irax
good point... but i thought the G20t was the turbo trim... or i guess the ones that i saw just had a turbo upgrade then...
Onizuka
the "t" stands for touring package, which is infiniti talk for upgraded suspension. There is a Q45t as well. And a I30t. None of them are turbo from the factory.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
J-Spec Tuner wrote:the us only has 1 version of the SR20, japan has 15+ versions of the SR20
No such thing as a FWD SR20DET, all the motors came with AWD trannies. GtiR produces 230bhp, Blue Bird(atessa) 205bhp. The newer SR20DET is referred to as an Avenir, has ball bearing T25 and doesn't come with a TMIC. GTiR is a hassle to tune and pain in the *** to get parts for. There is also a FWD SR20DE (Primera) 150bhp.
irax
OT:how hard would it be to convert the sentra's to AWD since they came like that in japan ?
RED_DET
Vendor
2011 Infiniti G37x
irax wrote:OT:how hard would it be to convert the sentra's to AWD since they came like that in japan ?
Too much work.....way too much.. just look under the sentra and imagine a drive shaft running to the rear end, the exhaust redone, what type of rear end you going to use, etc, etc..
MustangManV6
Car: 1995 Subaru Impreza
Does the SR20DET come with forged internals?
How long do the turbos last on these engines?
RED_DET
Vendor
2011 Infiniti G37x
MustangManV6 wrote:Does the SR20DET come with forged internals?
No forged internals, just lower compression pistons, GTiR (8.3:1) Blue Bird (8.5:1). GTiR has 444cc injectors, T28 turbo and quad throttle bodies. Blue bird has 370cc injectors, T25. Both motors have piston oil squirters. The turbos are normally good for 50-75K miles or more. Just depends on the abuse put on the turbo.
Bennitto Mallito
Car: Archaeology, surfing, sports,
^Con rods and crank are forged on DE DET is more of the same.
http://www.se-r.net/car_info/e....html
rps13 sr
Car: cars
RED_DET wrote:No such thing as a FWD SR20DET, all the motors came with AWD trannies. GtiR produces 230bhp, Blue Bird(atessa) 205bhp. The newer SR20DET is referred to as an Avenir, has ball bearing T25 and doesn't come with a TMIC. GTiR is a hassle to tune and pain in the *** to get parts for. There is also a FWD SR20DE (Primera) 150bhp.
bluebird is a altima in the us and its fwd with the sr20det.. if not in japan, then at least i know in hong kong the bluebird has a sr20deT which is the altima
Bennitto Mallito
^ Dude all altima (bluebirds) with SR20DET are fitted with attessa AWD system. No FWD DET ever rolled off a Nissan assembly line.
