Smurf6x6 »
https://forums.nicoclub.com/smurf6x6-u5616.html
Thu Jul 17, 2003 7:48 am
Colour match the wires to the ones on the switch. Splice them together. To check if the mirrors are working. (you have to remove the centre console and plug the switch into where the USDM switch was ). remove the door panels. and mirror bolt on the JDM unit. Feed the wires though the lower gramit thats going to the door (We tied the wires to a coat hinger and feed it though). Now connect, soder and electical tape your wires together and run it to the switch the same exact way you found the OEM wiring. Test it again and put your door panels and centre console back in. Hope this was helpful.
