JDM s14 plug location
firecrown
I need to find out which area on the wire harness the plug is comming out of for the Vac. solinoid that activates the EGR and Evap Can. On a s14. I have a imported s14 and need to plug in the vacuume switch to the harness but cannot locate the plug on the harness. I would rather find the original plug than run new wires for the switch and install a new plug. Any help would be apeciated thanx. :) A pic. would be great it runs well just has a lopie idle would like to get it back to as close to factory as posiable give it a tune up and see if it goes away if not the next step is to see if it has cams. It sounds like it dose right now
firecrown
I did find a wire harness layout that shows the wires and plug for the vacuum solenoid coming out of the harness area the alternator wires are coming from. I took a look at my harness and could not locate a unused plug in that area. Do not know if this book was for my specific year it was a section on a PDF. Anyone have a JDM s14 they could look at for me and tell me where theirs is?
