SWIFT_DRIFT »
https://forums.nicoclub.com/swift-drift-u892.html
Wed Aug 27, 2003 10:10 pm
You'll need the following:1) sunload sensor and the defrost trim it mounts in2) ambient cabin temp sensor and the trim it mounts in3) complete rewire of the US mode, heat mix, bi-level, and intake door motors4) fan control module (the US fan switch controls speed, the JDM uses a secondary controller)5) necessary thermo amps and resistors6) ALL wiring to all these components, or at least the plugs to run your own wires7) the JDM ECU to run the a/c compressor. (lol)
Good luck getting that stuff...At this point in time you are better off selling it to someone else who is uninformed as well. Doing the digital HVAC swap on s13's or s14's using the KA and US wiring is damn near impossible.
