BGdude »
https://forums.nicoclub.com/bgdude-u31954.html
Fri Sep 23, 2005 8:09 am
Thanks for your input, but the brakes are already on my car. They are little bigger than the stock 240SX caliper and the brake pads are also different, so I'm assuming the piston is slightly larger as well. I'm not sure if my OEM brakes were just beat up, but I feel those much better as far as braking. I need to turn the rotors, but eventually I will need to replace them and same with the brake pads, so what USDM Nissan are they compartable with? I will change the lines to SS, as that makes a difference. I didn't really swap the brakes as to have a "upgrade", I just had them and I figured they would be better than mine being newer. I will eventually upgrade to Z32 or Skyline brakes, but until then....Thanks for you help gents
