JDM Rearview Mirror
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
VersaMG08
Car: '10 Mazda 3 s hatchback
'14 Nissan 370z
Has anyone purchased a JDM Broadway Rearview mirror for the Versa? It says that it snaps onto the factory mirror, but I'm not sure if it will fit on the V. The mirror will not fit with a height that exceeds 80mm or less than 55mm.
Here is a picture
biggie
Could measure your mirror and find out.
KKaWing
Car: Versa SL Sport
I myself use one of those mirrors... However I use a convex mirror where the mirror curves out. Mine is just barely wider than the stock mirror 240mm? but offers a wider view out the back of the car allowing me to set the blind spot mirrors further out.
williamk10
Car: '07 Nissan Versa SL
i use the exact same one..no problems. The stock one is too small..but then again, all car's stock one's are too small for my liking
They Call Me Whatshisname
Car: 2006 Nissan 350Z
This is off topic, but william where did you get those sp10's and about how much did they run you?
SuperTurbo
This is a good brand to go with! Avoid those unknown one from parts source, and so on.... Those are garbage!
Don't worry about the height, the mounting at the back have spring inside, so all you really need to do is to clip it in.
Other than that, 2 things which you should worry is1. will 360mm a bit too long for Versa. (When you flip the thing to block some of the sunlight, you will hit the mirror)
2. You want flat or concave mirror. Flat mirror gives you a very real & true image, but concave with 360, you can see a lot more
Vahagn23
Car: Nissan Versa S
I have this. ITs the best mirror, it shows the passenger side aswell.
williamk10
They Call Me Whatshisname wrote:This is off topic, but william where did you get those sp10's and about how much did they run you?
http://www.tiretrends.com
$1200CAD with wheels and tires
VersaMG08
'14 Nissan 370z
I bought the 300mm JDM Rearview mirror from NLmotoring. I did the measurments and it came to about 12" W x 2 6/10 " H so it looks like it will fit. The 360mm is a bit wide and the visors won't come down. With the 300mm, it barely touches the visors so it won't be a big issue. I may have to move it just a tad for the visors to come down.
SuperTurbo
yea, 300 flat should be the better one to go.
I personally think 360 is way too huge for a Versa. Or try 300 curve, it's almost like 400 flat!
reyes1212
Car: '07 Nissan Versa Super Black
I have a flat and its a nice clear and wide enough view.My best bud's Fit uses the concave one...can't really see things well enough due to their bendy shapes, but I guess you get more of a spherical view.
Nismo V
Car: 2007 Nissan Versa 1.8S 2008 Scion xB 2.4L
You'll like it a lot I have a 270mm Flat/Night works good has a slight tint for night time driving. fits perfect..
blacksmaru
Car: 07 Nissan Versa SL
i have a broadway mirror on all my rides, i can`t drive without it, 270mm Flat should suit you best...
blindsnyper
Car: 2007 versa
what does anyone think about a convex 240mm????
devilV
Car: 2009 Nissan Versa
Ok, I'm bringing up an old post...anyone have pics of their mirrors? I'm trying to decide on 240, 270 or 300. Thanks in advance.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
devilV wrote:Ok, I'm bringing up an old post...anyone have pics of their mirrors? I'm trying to decide on 240, 270 or 300. Thanks in advance.
I don't have one (YET) but it's been said in 2 posts that the 270 fits best and another post saying that the 300 doesn't quite clear the visors perfectly. You take your pick from that information.
devilV
OK....disregard. I just got the 270mm. The 240mm would be too small.
VersaMG08
'14 Nissan 370z
devilV wrote:OK....disregard. I just got the 270mm. The 240mm would be too small.
I have the 300mm, fits PERFECTLY. Just enough room for the visors to flip down!
Codelicious
Car: 1989 Nissan 240SX
VersaMG08 wrote:I have the 300mm, fits PERFECTLY. Just enough room for the visors to flip down!
Post a picture for us? :D
VersaMG08
'14 Nissan 370z
This is what it looks like when mounted (visors up)This is what it looks like when visors are flips down, about an inch of clearanceThat is the 300mm flat broadway rearview mirror
steed77
Car: 09 Versa Fresh Powder Sedan 6speed
nice to see one installed, thanks..... I just ordered a Broadway JDM Convex Blue 270mm
Return to “Versa Technical Discussions”
