However that's all that happens, no movement. I was able to pull the end with the light out an inch or so and it was not lit up.
After I was able to pull the light part out and re-collapsed it, I can now here the motor going when I flip the switch, no moment on the pole though .
Is there a fuse anywhere I should check? Or do I need to take the bumper off and dig around back there? Wd40 the telescoping bits? Any help or ideas are appreciated.
