JDM guys, need help with R32
Bandit240
Car: 1980 Datsun 720 King Cab
OK i was given a R32 front clip (stripped) and i want to know how she died. I have made a Paintshop copy of the VIN plate. It has a few jap. writing on it so i cant put those in the BMP file. I will try scan or get a better camrea to take a picture of it for me. My camrea just sucks. I ahve all the info i could copy from the plate on there. Thanks for any help yall can provide.
themadscientist
well I can see it's a GTS-T but to my knowledge you can't just go get a carfax-like report on cars in Japan off the street.
Bandit240
Hey mad you wouldnt happen to know if the clucth pedel and cylinder off of that would work on a 240SX would ya?
themadscientist
If you can wait until tommorow I'll check in my Nismo catalog tonight if the clutch support is the same. The master should be the same between the R32 and S13, the R33 is a little weird but the R32 is the same.If the 240 is like the Silvia get a hole saw because the won't be one in your firewall. It's a royal pain in the butt to drill under there!:mad:
Bandit240
I already ahve that done. Its just waiting for the parts to get in. All i need now is a transmission
themadscientist
they are all hydraulic on late model Nissans, you're good.
Bandit240
Mad whats your E-mail? Mine is [email protected] I ahve a few pics of the master.
themadscientist
You got mail
themadscientist
the support is a different #, the pedal will likely not work in the 240.
Bandit240
The pedel fit!! i put it in today. Now all i need is the lines and a transmission.
themadscientist
great. So you have the pedal and master cylinder mounted, you just need the transmission, slave cylinder, crossmember and likely the front shaft.
Bandit240
OK then. where does the slave cylinder go? I know about the rest. There isnt one on my clip so ill have to buy it when i buy the transmission. Now also need a brake pedel too. Its weird getting into my car with that big *** brake pedel and a clutch pedel
Bandit240
Hey Mad can you tell me if that thing had HICAS?? It has an eletric power steering pump that has lines leading to the rear. I wonder if i can use it as a P/S pump on my car?
1dollar240
Bandit- there is one important line that you need for this swap. I cut it when i pulled the old motor and then realized it was a dealer item, then had to wait a week for them to order it. Its the rubber hydraulic line that connects the hardline to the slave cylinder. About 18 bucks at nissan. I just wanted to warn ya so you dont get everything together and then have to wait a damn week for a stupid hose like i did.
Bandit240
LOL i will get it.Right now i need the key code for the R32. I found out it has a telescoping steering wheel. Im gona retrofit it into the 240. Mad can you get me the key code useing the info on the plate?
