CrazyInteg »
https://forums.nicoclub.com/crazyinteg-u40151.html
Fri Apr 28, 2006 2:41 pm
I had my buddy do the kph->mph resistor mod to the jdm speedo. I swapped over the speedo and tach to the gauge cluster in my 1991 240sx. When I turn the car on, the tach takes like a minute (seriously, 60 seconds) to go up to 1000 RPM, and the speedo moves very slowly too. These guages have sat for about 3 or 4 years without ever being used.I unplugged all the wires to the cluster, and the tach and speedo go to zero. When I plug the harness back in, they read about 300 rpm and about 5 mph with the motor off.
Also the blinkers dont work!
What's the deal? I didn't swap the USDM guages back over yet, but they worked before I swapped the JDM ones over. The only difference in the car is that I changed the ECU today before I installed the JDM guages.
Also this is my first post in NICO
EDIT: OK I swapped the USDM speedo back over, and it works just fine. The blinkers do not work still. The tach goes up to the RPM and then just sits there. It's like peak hold.
Modified by CrazyInteg at 6:45 PM 4/28/2006
