JDM gauge clusters
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
does anyone know if the gauge cluster from a s13 ca18det will work with a sr20det? or will it run into the same problems with running USDM single cam guages with the sr20 signal?
Redline240
Car: 95 240sx
i got a question, is there an aftermarket or JDM cluster for the S14?
S13240
J-Spec Tuner wrote:does anyone know if the gauge cluster from a s13 ca18det will work with a sr20det? or will it run into the same problems with running USDM single cam guages with the sr20 signal?
Will not work with sr20.
