JDM Fuga exhaust
mh_notorious
Car: Nissan Fuga 350GT
Hi guys I'm new here and own a 2006 Y50 Fuga.
Been contemplating changing the exhaust and right now confused between a Japan sourced TRUST exhaust or Stillen from the US. Both these sound just right but the stillen sounds like it has a lot more resonance at idle. And it seems the TRUST unit is more expensive too. Anyways trying to make up my mind.
I would really appreciate your opinions. Also ordering a AP big brake kit.
http://www.stillen.com/product/brake-ki ... 29735.html
Now my last concern is that the car is riding on stock 19" alloys with 245s all around and I want to change to 20" with 275 at the rear while keeping 20" 245 at front. Does this require any spacers and what size do I need to order..as in 20 * 10jj? Hope I'm clear and looking forward to hearing from you guys!
pharaohEG08
Car: Black 08 M35
Congrats on the M, welcome to the forum.
I don't know much about exhausts because I haven't looked into getting one. But I have 20x8.5 f on 255-35 and 20x10.5 r on 275-35. The fronts don't sit flush with the fender (5mm spacer would fix that i think) and the back stick out about 1/4 inch or less. My wheels don't have a huge lip so imo my staggered setup looks bada** and you can really see the stance when following or driving ahead and looking into the rear view mirror. My recommendation, if you are not buying used wheels from someone and ordering specific sizes then go with 9.5f and 10.0r and you will be good; even with fat tires in the back.
mh_notorious
Thank you! I was just going through the Technical Specifications pdf and it mentions the car with 19" comes with 8.5JJ.
I was wondering if your front 20"s at 8.5 sit don't sit flush then isn't 9.5 f going to create even more of a hassle?
pharaohEG08
Car: Black 08 M35
well 9.5 is a wider wheel therefore it will fill up more of of the wheel well width wise.
mh_notorious
Hmm. But it's still safe to order 20" 8.5f and 10r and wrap them in 245 f and 275 r?
mh_notorious
http://www.vossenwheels.com/wheels/VFS2.aspx
i'm pondering over these! Can you help me out with the bolt pattern?
