CA18DET 89-91 - Engine, 5-Speed RWD Transmission, ECU, Complete Wiring (Un-Cut) has about 50,000 miles on it. You get:
- Complete Motor with all accessories and turbo.- 5-Speed RWD Transmission- Computer(ECU)- Wiring Harness(complete)- 60 day warranty on the engine block and head(internals). Each engine is compression tested and results are provided with each engine.
$1999 shipped
SR20DET 91-93 - Engine, 5-Speed RWD Transmission, ECU, Complete Wiring(Un-Cut), Ignitor Chip, has about 45,000 miles. You get:
-Complete Motor with all accessories and turbo.-5-Speed RWD Transmission-Computer(ECU)-Wiring Harness(complete)-Ignitor Chip- 60 day warranty on the engine block and head(internals). Each engine is compression tested and results are provided with each engine.
$2899 shipped
SR20DET 91-93 - Engine, 5-Speed RWD Transmission, Computer(ECU) has about 47,000 miles on it. You get:
- Complete Motor with all accessories and turbo.- 5-Speed RWD Transmission- Computer(ECU)- 60 day warranty on the engine block and head(internals). Each engine is compression tested and results are provided with each engine.*** Wiring Harness and Ignitor chip not included.
$2499 shipped
BlueBird SR20DET 90-94 - Engine, ECU, Intercooler has about 50,000 miles on it. You get:
- Complete Motor with all accessories and turbo.- Computer(ECU)- Intercooler- 60 day warranty on the engine block and head(internals). Each engine is compression tested and results are provided with each engine.*** Transmission, Wiring Harness and MAF sensor are NOT included.
$2399 shipped
GTi-R SR20DET 90-94 - Engine, ECU, Intercooler has about 50,000 miles on it. You get:
$2499 shipped
VG30DETT 90-95 - Engine Only has about 45,000 miles on it. You get:
- Complete Motor with all accessories and turbo's(2).- 60 day warranty on the engine block and head(internals). Each engine is compression tested and results are provided with each engine.
$2199 shipped
R33 RB25DET 93+ - Engine Only has about 47,000 miles on it. You get:
- Complete Motor with all accessories and turbo.- 60 day warranty on the engine block and head(internals). Each engine is compression tested and results are provided with each engine.
$2799 shipped
R33 RB25DET 93+ - Engine, 5-Speed RWD Transmission, ECU, Complete Wiring(Un-Cut) has about 39,000 miles on it. You get:
- Complete Motor with all accessories and turbo.- 5-Speed RWD Transmission- Computer(ECU)- Complete Wiring Harness(Un-Cut)- 60 day warranty on the engine block and head(internals). Each engine is compression tested and results are provided with each engine.
$3299 shipped
R32 RB26DETT 89-94 - Engine Only has about 41,000 miles on it. You get:
- Complete Motor with all accessories and turbos(2).- Complete Wiring Harness(Un-Cut)- 60 day warranty on the engine block and head(internals). Each engine is compression tested and results are provided with each engine.
$3299
R32 RB26DETT 89-94 - Engine, 5-Speed AWD Transmission, ECU, Complete Wiring(Un-Cut) has about 50,000 miles on it. You get:
- Complete Motor with all accessories and turbos(2).- 5-Speed AWD Transmission- Computer(ECU)- Wiring Harness(complete)- 60 day warranty on the engine block and head(internals). Each engine is compression tested and results are provided with each engine.
TEMPORARILY OUT OF STOCK
SR20DET 94-98 - Engine, 5-Speed RWD Transmission, ECU, Complete Wiring Harness, Ignitor Chip has about 49,000 miles on it. You get:
- Complete Motor with all accessories and turbo.- 5-Speed RWD Transmission- Computer(ECU)- Wiring Harness(complete)- Ignitor Chip- 60 day warranty on the engine block and head(internals). Each engine is compression tested and results are provided with each engine.
$3299 shipped
Contact Jayson at [email protected]
