Not totally sure what you mean by usdm but the business is in California. I found this auction on ebay and called the guy. He says they drive the cars over in japan to test them and then bring over whats useable. He said it runs perfect and the car actually had 28k on it. Plus you mentioned the different connectors but my car is a 91 and the motor is a 92-93 he said, so it should just basically be plug and play right?tmeyer29 wrote:A ecu from a 96 will be different than 90 to 95. The 95+ ptu is different and requires a different connector. 95+ also uses the new style injectors(also differenent connector). Why not get a USDM motor?
