elwesso wrote:Yeah at this point, if you were to get a 1994 engine it is STILL 16 years old even if its got low miles, so its going to need to at least be looked at for things like VC seals, hoses, etc.
The main thing is how clean they look.. Take off the valve cover (pass side is easier), and look at the heads. If they are nice and clean (maybe a slight amber color), you're going to be better off taking that engine than a much lower miles one that looks nasty inside.
Mileage shouldn't be your major concern, it should be their maintenance.. a well maintained engine will go 300k miles easily without losing compression or needing rings.
Yeah, ain't that the way? Buying a "new" 15 plus year old motor to go in a 30 plus year old car!
I don't mind seals, gaskets, some wiring, replacing connectors etc. It's the coil packs, PTU's, and fuel injectors I'm concerned with.
My plan is to use a 90-95 engine with 90-93 engine wiring harness and 8 bit ECU. This eliminates the need for a stand-alone and for my purposes (NA) the ECU will be plenty tunable.
Any suggestions graciously accepted! TIA
chris
