Pwnin O'Brien »
https://forums.nicoclub.com/pwnin-o-brien-u136941.html
Thu Oct 22, 2009 7:36 am
He's got the JDM blacked out headlamps/corners; the headlamps do have reflectors but only the reflectors are chrome, the rest of the lamp is black (you can see them on my car in a different thread). I doubt, however, that you will be able to find blacked out corners without any orange in them at all. The DOT requires some orange on the corner lenses to indicate the front of the vehicle (I know, stupid), so I doubt any companies would manufacture and sell them illegally. The clear corners do not have any orange, but they use reflectors and even then you can get a ticket for using clear bulbs instead of orange bulbs.
I think the easiest solution is to modify your current corners. You can simply heat up the corners (either using the baking method or a heat gun) and pull the lens from the assembly. The orange portion of the lens should be a separate piece which you should be able to just pull off of the lens (the orange piece may be glued or something, so be careful).
Another solution would be to purchase clear corners, separate the lens from the blacked out set and the clear set and then just swap them (put the clear lenses on the blacked out assembly).
