JB Weld
2d-ink
Okay I manage to break a bolt on the Thermostat housing on the lower timing chain cover. Well I need to get it fixed fast before the school year end so I can drop in my engine. I drilled the old bolt out and try to tap it but there wasnt enough room so the thermostat housing cracked on the top portion of it.
My question is can I use JB Weld to fill in the Hole and then drill and Tap it for a bolt will that hold?
drifTR
Car: 1993 Nissan 240sx SE
Hey I had the same problem i broke a large chunk of my thermostat housing off and am trying to fix it till i have enough $ to get my SR20 did the JB Weld work
