Javascript gurus...
RobDET
Car: Cars
I wanna do this...
function enableField(checkbox,fieldname){ if (checkbox.checked) { document.Form1.(fieldname.value).disabled = false; document.Form1.(fieldname.value).focus(); } else { document.Form1.(fieldname.value).disabled = true; } }
I can't get it to work. I'm sure the syntax is incorrect but the goal is to make the function dynamic. I want to be able to activate any field based on any check box.
The problem is (fieldname.value) doesn't work at all and if you just put .fieldname. it doesn't put the contence of the variable there it just trys to look up the literal object "document.Form1.fieldname" Which doesn't exist.
TrueSlide
Car: Stuff
I would assume your problem is lies here:if (checkbox.checked)
what is checkbox.checked suppose to equal, true? false? 1? 200000?
RobDET
Car: Cars
that part works... i've tested it... it returns a ture/false value.
