Japanese "ROCOM" wheels? Anyone know anything? Pics. inside....
Chingon
Car: 1991 and 1992 hatchbacks
Pcd 114.36.5x15offset 38
Anyone know anything? Construction method? New company name/merger? Thanks ahead of time.
Modified by Chingon at 10:27 PM 7/2/2005
chmercer
looks like an average old school 4 lug wheel. if the seller knows the weight you could pretty much determine if they are cast or forged, but if i had to guess, i would lean strongly towards cast. sizing reminds me of honda wheels but the bolt circle is wrong.
BaliLover
Bolt pattern and wheel size would work on a 90 and newer 4 lug Accord and Prelude
Chingon
chmercer wrote:looks like an average old school 4 lug wheel. if the seller knows the weight you could pretty much determine if they are cast or forged, but if i had to guess, i would lean strongly towards cast. sizing reminds me of honda wheels but the bolt circle is wrong.
I thought that at first, but then again offset is relatively low and the pattern is wrong. I'm sure they're probably fwd oriented, but the size and offset is fine for the s13 chassis I think. Here's a few pics on my bro's ride (mine would need a 5 mm spacer to clear the 26 mm calipers in front, rear z32 were fine). BTW, they were mounted on 205/50/15's and he has stock suspension, so that's why the gap (not too bad I don't think). As for the construction method, they are probably cast (spun rim I hope)...
Modified by Chingon at 5:17 AM 7/3/2005
ytboy4ever
Car: '87 TII
'92 Coupe
'86 CRX - dd
i see an FC in the background
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
The look good, so who cares
