rps13det wrote:what kind of kg/mm springs do you have? I had the blue ones before with some japanese shocks. the ride was stiff as hell, because i was riding on the bumpstops the whole time. Basically i was somewhate bottoming out. you should check to see if you have any travel for the shock and bumpstops. the kg/mm springs were made for track use, the cornering with these springs are excellent with minimal body roll. the only problem is that there are a lot of shocks out in the market that are (standard) long stroke shocks. to fully utilize the springs' potential you need to use short-stroke shocks. dunno if they even make any at all.
I have the blue ones, with Bilstein "sport" shocks. My car is riding on the bump stops too because the guy who owned it before me, obviously had no idea how to properly setup a suspension.
What did you end up doing for your suspension setup? I'm looking at getting some coil-overs, as soon as I figure out which kind are going to give the best ride quality.
