zach-Ka wrote:+1 All is great advice. I wouldnt swap motors yet. Just get the sohc running good then start on drivetrain and suspention. I reget every day that I didnt do all this before a went sr.
It's a dual cam... The KA24 was swapped before I got the car. I think this is what I am going to do though.
OutToWinPAHC wrote:Oh and FWD RWD, Honda, Nissan, or even Daewoo... Its all the same when checking a head gasket. Try to check compression, check for intermix in the oil/rad, check for constant air bubbles in the rad.
If you pull the head and buy a gasket set, clean the hell out of the head and take it to a machine shop. They usually can check a head for 15-20 bucks and if it needs milling its usually 40-50 more bucks. Then take a straight edge to the block and some feeler gauges and make sure its straight.
Since you heave the head off now is a good time to replace the tensioner, and timing chain too.
The mix between oil/cool is 100%... meaning... oil is milky. I am talking to someone about replacing the gasket, head bolts, and the thermostat(because there is none in the car currently). I know the person who swapped this motor, so I am going to guess that he did check/replace those already, but I will still say something to them - thanks!
Also, since you removed the easy link to the linked picture (it's ok, I understand)...
The pictures that I had taken was kind of crappy. Not sure why... I did let my aunt use my SLR before me and she could have did something to the lens - touched it with her palm or something to create the hazy affect. I'll try to take some more today or this week. Although, it is raining today
Pictures are here. Hopefully they resize automatically.
