From
http://www.jagweb.com/aj6eng/v8_performance.html :
"It is perhaps then not surprising that on the Jaguar V8 the tensioners on the secondary camshaft chains in particular have developed a reputation for being troublesome. In fact it may not be that there is any weakness in the tensioners themselves, rather that at certain critical speeds heavy torque reversals on the chain can produce higher than expected stab loads, a condition which can probably be exacerbated by some usage patterns. It is perhaps interesting that the later 4.2 V8 uses more rugged morse internal tooth primary chains and that when BMW introduced a similar V8 (four valve, twin OHC, Nikasil bores, sintered fracture split con-rods) in 1992 they used duplex chains throughout. Whilst Jaguar's design team, in choosing a single link chain drive, did specify that it should be rated for heavy duty, one wonders if there have been any regrets that space wasn't made to use a duplex chain rather than relying on the lightweight valve gear to let them get away with the narrower option?"
It includes an interesting comment on high sulfur fuels and Nikasil liners?"With the benefit of hindsight the decision to use Nikasil plated cylinder bores instead of conventional liners might be judged a bad mistake, but it is one that was understandable and which caught BMW off-guard as well. The Nikasil process had been used for years on motorcycle engines and is in common use for F1 and other racing engines so it is hardly unproven technology. At the time BMW's exceptionally tight control of oil on the bores was thought to be a factor in their troubles, which would not apply elsewhere. In truth, instances of failure of the Nikasil coating appear to have been induced by poor fuel quality in certain markets allied to short journey usage, and engines running on low sulphur fuel would be most unlikely to suffer the problem. Jaguar resolved service failures in an honourable fashion but eventually decided to abandon Nikasil and revert to conventional cast iron liners (from VIN 42776 XK8, 878718 XJ8). The advantages of light weight and close running clearances were sadly lost. Ironically the fuels which caused the problem have now virtually disappeared from the market."
And an interesting comment on the XJ8R supercharger set-up:"The supercharged V8 is an impressive performer yet flow through the intercoolers is a little constricted and the Eaton roots supercharger is not very efficient, so it could have been even better. For example, a more efficient screw type of supercharger would provide an immediate gain of around 40 b.h.p. and would make possible quite a lot more than that. Anyone interested in a more detailed explanation of why might care to read the feature about supercharging technicalities found elsewhere on this website."
And a cautionary note on why stroked motors are cheap ways to power, but not always desirable for long term durability:"The size increase to 4.2 litres was obtained by increasing the stroke - always a favoured approach at Jaguar - necessitating the crankpin journals to be reduced in diameter to maintain the same block height."
