RobPaulson wrote:
i saw this, and this is exactly why i'm asking this question. the jack i WANT to use has an EXTREMELY larger area than the OEM jack that fits nicely into those 'teeth'. If there happens to be pressure somewhere its not supposed to be, it could be bad news.
And yes i'll be using jack stands, i'm not planning on going under my car, i just need to take the wheel off and dont want to use the PoS OEM jack.
As long as you keep the jack in that general area (and not on the side skirts) you're fine - you're jacking up the frame at this point, and structurally you are not going to have any issues doing this - I have 2 floor jacks at my house and I use both of them to change my oil, as well as using them to get the car up to paint my calipers (3 times...).
Realistically, putting the jack anywhere along that line is going to be fine to jack the car up - you're right on the frame. Putting it in the middle would just do nothing helpful for you lol.
Consider also the lifts that some shops use that place long beams along that line too - you're doing the same thing with your jack. Like I said, as long as you have the jack on that metal bar and keep it clear of your side skirts you'll be golden
