onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Tue Jul 12, 2005 12:29 pm
Ok guys, well, after installing my coilover/swaybar setup, it seems jacking up the feels a lot more dangerous (or it could just be pyschological). Problems are occurring w/ lifting/lowering procedure & placement of jack stands - 89 240sx coupe.
Here's what I do:
1) jack up the front a little on the driver's side at the front tow hook (to make space for the other jack for step 2 - car is lowered)
2) jack up the driver side the rest of the way at the "spare tire" jack up point which is f'ed up on all 4 corners
*** Car starts lifting on 2 wheels, not super bad.. yet
3) put in shorter jack stand (of the 4 I have - 2 diff sets) on the frame tube closer to the inside of the car.
4) Repeat for passenger side
*** Now it starts gettin a little hairy
5) Start at rear passenger side, once I start lifting up, it seems the car decides it wants to be all 4 wheels in the air and starts teetering on the driver side stand and the jack - doesn't feel safe at all for me at this point
*** Also note that the frame tubing has parts of it "giving way" and doesn't seem like the most secure place to put the jack stands. Is there a better place to put these stands?
I'll finish jacking up the car, but there must be a better way where your car doesn't float/wiggle/dangles all over the place.
It gets even worse when removing the jack stands.
Anyone have a better method/way/placement?
