I am about to work on rear subframe of S14, 96Don't know which are the good spots to jack-up and to put jack stands.
1. Where i should put the jack in order to lift up the car ? (pls, tell me for both front and rear)(the spots in the manual are look like blade to me; I'm sure that it will bentif I jack up that spot, and if I put the jack there, i don't think there is enough space left for put the jack-stand in)
2. After I lift the car (rear/front) where I should put the jacks stand to support the car.
pictures would be awesome.because a picture worthes 1000 words, doesn't it :-)
I know this question is toooo easy for you guys, but I justdon't have luck from searching.
Thanks Thanks..
