For the J30:1st 2.78:1 2nd 1.54:1 3rd 1.00:1 4th 0.69:1 reverse 2.27:1 Final Drive Ratio (:1) 3.92:1
The AT gears ratios are the same as the 90-93 Q transmission so after correcting for tire diameter differences : 3.92/3.538= 10.8% + 4% more revs at same speed. or ~~~2350 rpms at 60 mph in 4th.
http://www.nissannews.com/?htt...shtmlFront Suspension Extended-travel MacPherson strut type w/ 24.0 mm stabilizer bar Rear Suspension Patented, new generation, double-isolatedmulti-link type with 19.1 mm (Base), 17.3 mm (t)stabilizer bar
Fuel Tank (gal.) 19 Engine Coolants (qts.) 9.75 with reservoir Curb Weight (lbs.) 3,527 (J30)/ 3,533 (J30t) Weight Distribution (F/R %) 57/43 FUEL ECONOMY* Highway/City (mpg) 23/18 0 - 60 8.3 sec. ** 1/4 Mile 15.0 sec. ** Maximum Speed 128 mph * EPA estimate for comparison only, actual mileage may vary** 1993 Model Tested
