I need your expertise on my 1994 J30t transmission problem.
SITUATION:It don't want to shift from 1 -> 2 gear with in the first 3-5 mins of driving; perfect shifting after that
WHAT I HAVE DONE:Did the complete flush with pan drop and replaced the filter, gasket, and O-ring (Mobile 1 ATF). No luck so far though....
ADVICE NEEDED: I have read most of threads with similar problems and this is where I need you guys help. Should I take the car to a dealer and run the diagnostics with CONSULT? (costs US $90) or should I buy a revolution sensor (costs US$135) and try it? Any advices?
Thanks in advance.-A guy with 1994 J30t with 87K miles.
