jldyer »
https://forums.nicoclub.com/jldyer-u216866.html
Tue Aug 12, 2014 8:55 am
I need a little help on this one.
My steering wheel has been shaking for over a year now. It shakes between 60 & 70 while accelerating/normal driving and it shakes around 40 when braking. I've replaced the front outer tie rod ends, the rear brakes (new caliper on passenger side, new rotors, new pads), new struts on the back (used the KYB struts recommended here, new tires on the back (which were eaten in one year due to, I believe, the cause of the steering wheel shake).
What should I replace next? I was thinking of the inner tie rods (front and back). Remember this is a 't' model, so it has hicas on the rear.
What else could be causing this shake?
Thanks.
