msudawgs98 »
https://forums.nicoclub.com/msudawgs98-u12622.html
Sun Jan 18, 2004 10:18 am
When I bought my J30 last month, I noticed that the antenna was broken and needed to be replaced. So, I got on e-bay and was able to buy the whole antenna assembly. I thought it was goin to be a simple plug and play but as I turned on my radio, nothing happened and when I turned off the radio, the antenna raised up. I was confused. One note is that the previous owner had replaced the stock Bose system with a pioneer head unit and he did some wiring to make the speaker work somehow. Anyway, there is a slew off rats nest wires in the dash that I didn't know where to start. I opted to look at the power antenna end (trunk to see whether I can just reverse the polarity of the wires so that it will work opposite from how it is working now. I noticed that the power antenna itself (motor) has 5 wires (red, black, brown, blue/red, and yellow) in the male connector. The connector coming from the head unit itself only has 3 wires (black, yellow/red, and green/orange) in the famale connector. My question is which of these wires can I switch so that I can get a desirable result from my power antenna. I need help!
