J30T headlight problem
a100pureplayaz
Car: 1993 infiniti J30T SOLD 1995 Nissan 240sx sr20det redtop
ok i got my J30 from my brother a week ago and first of all its aweosme i just had one question the headlights keep shutting off by themselves then turning back on both the driver then passenger in no specific sequence just continue shutting off any ideas?
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
check contacts, always start with the simplist possiblilities, that way you will avoid spending unneeded money, remove the lights and clean the plugs with a contact cleaner "found in most hardware stores" , also check the fuses, if that doesnt work, get s pair of new bulbs, make sure the bulbs are 55W "i installed 80W bulbs once, it partially melted my wiring". i hope this helps
yodawill2000
Car: 94 Infiniti J30
Could be the relay as well .Thats the prob I had .. simple fix .
go to http://www.fuzzycats.com then click the J30 then the DIY link .. you will see the procedure for fixing it , or buy a new one , not to expensive .
DominickJ30
Car: 1993 Infiniti J30t
It is most defenitely the relay, seems like every single J30 has this problem lol.
Elisha
Car: Infiniti J30
i have this problem occasionally when my driver side lights go out and comes back on occasionally.and the dash lights went out on me once too.
kccake
Car: i994 infiniti j30
it is the relay i had the same problem with mine a week ago and cleaned all the contact at the head light and cleaned the relay and havent had the problem since!!!!
DominickJ30
The problem with the realay is internal, so expect to have the same problems unless you buy a new one, or resolder the old one.
yodawill2000
Takes 10 minutes to resolder all the cold solder joints .
Mine hasnt blinked since.
driverdriver
Car: NICO's longtime resident Canuck!!!
Elisha wrote:i have this problem occasionally when my driver side lights go out and comes back on occasionally.and the dash lights went out on me once too.
Could be your DRL relay or the normal headlight relay. Do your DRL's work?
Elisha
Car: Infiniti J30
driverdriver wrote:Could be your DRL relay or the normal headlight relay. Do your DRL's work?
where are the DRL relays located?what does DRL stand for anyway?
driverdriver
DRL stands for Daytime Running Lights. All Canadian vehicles must have them due to federal transport safety law. The law has been in effect since 1990. The DRL module is a small white box, that is located on the driver side of the engine bay around the top of the left wheel well (and sometimes just behind it).
Tap it with the handle end of your screw driver. If your lights either come on or go out that is your culprit.
