J30t Front & Rear Struts
J30onDubz
Car: CARS and HOTRODS
I realize it has been talked about many times before, but what are the part numbers of higher performance replacement struts (both front and rear) for a J30t?? Does KONI make them??
ThanksJON
Mayhem_J30
Car: Ummm...My Car
HAHA, there are none. There are Koni's that will fit the fronts as inserts though.Koni Yellows part # 8641-1362SPRT. $135.80 each from shox.com
WOOHOO!!! POST 2000!!! :dogpile
diamondj30
Car: Not to low , not to high , just right .
good going chris,havnt seen that # in awhile.for the back you will have to have some fabricated.for koni to make rears its 1250.00 double adjustable.thats what i run in the rear.
madmax88
Car: my car
cool ''some fabricated.for kdouble adjustable.thats what i run in the rearoni to make rears its'' what kind of fabrication? and inserts what do you mean by this Chris?
Eswift
Car: should be obvious enough
madmax88 wrote: ''some fabricated.for kdouble adjustable.thats what i run in the rearoni to make rears its''
haha all we need,sounds like weve got a canadian rapper on our hands...
Mayhem_J30
Car: Ummm...My Car
madmax88 wrote: and inserts what do you mean by this Chris?
The front struts are kind of rebuildable. You keep the outer frame of it (where the spring sits) and replace the inside with new dampers. Inside the original is an ugly hydraulic fluid mess, but the replacement cartridges are easy and just slide in. I'm not sure how else to explain it without writing a page and without pictures.
diamondj30
just one thing,those konis are for lowered j30s.i say this because when i had koni match them up i told them the car was dropped.may want to check rod length nif not lowered.me and chris have lowered j30s.
