yodawill2000 »
https://forums.nicoclub.com/yodawill2000-u27169.html
Sat Oct 31, 2009 1:29 am
All the OEM Bose speakers have their own amp.That's why a scosche adapter is needed to bring down the gain to each speaker if a aftermarket unit is installed.It sounds like the harness they used wasn't correct ??The rears should work but be distorted because of the amp issue.Note the Bose System uses 1 Ohm speakers while most aftermarket systems use 4 ohm.
