mobilefleet »
https://forums.nicoclub.com/mobilefleet-u96096.html
Sun May 04, 2008 4:27 pm
bought a 94 J30 that had sat for about 6 months. Previous owner said car had started running rough/stalling so he parked it and got another car. I bought the car, checked compression (180 or so on all cyl.), spark was great, but then discovered that 3 of 6 plugs were not wet with fuel, so figured those were clogged. Knew it was a big job changing injectors but got it done using dremel method. BEFORE I did any of this, checked ECM and it had no codes. After work was done, car started but ran very low idle, about 400-500 RPM, and if you give it gas it popped and backfired pretty hard (I observed the air intake shake as it backfired, apparently through this and not the exhaust). I got it to where it would rev to about 5-6000 RPM but it was still rough. Now it will not start at all. Check engine light had come on after backfiring and I got codes 34 and 51 for knock sensor and injector analysis, whatever that means. I also put fresh premium fuel in the tank. Can the knock sensor keep it from starting? Any other ideas? It acts like it wants to start but won't light off and run. It's getting frustrating. I wouldn't think the knock sensor would keep it from running but maybe so?
