J30 won't start after California Trip
Papasmithnc
Car: 1994 j30, 1994 Mitsubishi 3000GT, 1995 BMW 325i Vert
My daughter parked her 1994 J30 for about 10 days while she was visiting friends in Cali. After returning, she tried to start her car. It turned over fine, we hear the fuel pump come on, but the car will not hit a lick. We thought it might be out of gas. We added gas, let the fuel pump prime the injectors but, still no luck.
Where should I start in diagnosing the problem? My daughter really needs to have this car running.
Thanks,Dave in NC
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
Papasmithnc wrote:My daughter parked her 1994 J30 for about 10 days while she was visiting friends in Cali. After returning, she tried to start her car. It turned over fine, we hear the fuel pump come on, but the car will not hit a lick. We thought it might be out of gas. We added gas, let the fuel pump prime the injectors but, still no luck.
Thanks,Dave in NC
start by checking the codes in the ecu...heres the link...zerothread/217489you also might try the flooding procedure....after my 94 sat for 28 days while i was @ work offshore i had to do the same thing to get her to start...hope that helps
Papasmithnc
Thanks for the info. What is the flooding procedure?
Dave in NC
seattlesanman
Try unhooking the battery for a day, then hook up and crank for up to 10 seconds at a time.
yodawill2000
Car: 94 Infiniti J30
Papasmithnc wrote:Thanks for the info. What is the flooding procedure?
Dave in NC
Holding the pedal to the floor and keep cranking till she fires.
Papasmithnc
Thanks. The "flood procedure" or pushing the pedal to the floor and cranking until it fires worked. Of course, to anyone else having the same problem, don't crank over 10 or 15 seconds as it is hard on the starter.
Thanks again to all those who responded for the help.
Dave in NC
yodawill2000
Good deal !!
